It is currently Mon Jul 28, 2025 12:19 pm
PostPosted: Tue Oct 04, 2005 9:05 am
Through a little creative horse trading I have acquired a very old, very dark set of BRW.
It was really one of those deals you just can't pass up (even if I just end up using it for "parts"). However.....
The back plates are a little thin. .085"
Would you even try to build a guitar with this?
PostPosted: Tue Oct 04, 2005 9:11 am
Thin? I'd take them down another .005"....
Honest!
PostPosted: Tue Oct 04, 2005 9:12 am
I don't see that big a problem. I have built that thin
john
PostPosted: Tue Oct 04, 2005 9:14 am
I've heard of builders bringing it down to .070", so you're ok.
PostPosted: Tue Oct 04, 2005 9:32 am
Giddy up Brock
couldn't resist.
PostPosted: Tue Oct 04, 2005 9:34 am
Brock..
I believe it is too thin. You better send them to me asap.
Ha Ha Ha!!!
Walter
PostPosted: Tue Oct 04, 2005 10:05 am
I'd say there just about perfect. With finish sanding and all they'll be down to .075 easily.
PostPosted: Tue Oct 04, 2005 10:06 am
Thanks. I usually take my sides down that thin, but rarely do I let the back go down that far.
PostPosted: Tue Oct 04, 2005 10:18 am
That puppy is going to sing! Somogyi -" build to just before failure" - gonna feel like there's a motor inside.
PostPosted: Tue Oct 04, 2005 11:50 am
I've repaired old Martin's and Gibsons in the .055" range and they still sing like angels on steroids.
tim...
PostPosted: Tue Oct 04, 2005 1:57 pm
Depending on the model/wood stiffness/my mood I normally go down to
.070-.080. Have at it dude! Post some pics of this set too!
PostPosted: Tue Oct 04, 2005 2:14 pm
You should have no problem with that thickness. Almost all of the classical guitars I build are BRW and the thickness is at that thickness or thinner. Note that I am building classical dimensions so I have no experience as to stability at dread type dimensions.
The really dark sets I find to be more fully oxidized and much more stable than younger, more colorful (lighter) sets. That being said, I also reinforce the sides with linen tape which is accepted in classicals whereas steel strings typically have side braces. This is a good idea as BRW is not always stable and you will have little control after the guitar leaves your shop as to how it is kept humidified.
While I dont build cutaway classicals (some say that they ae no longer classical) I have built very tight waist bends on reproductions of historic instruments and have thinned sides to about .065 with no problems or cracking.
The sound should be killer.
PostPosted: Tue Oct 04, 2005 2:18 pm
This is an eye-opener for me as I've not yet built anything with Brazilian rosewood (will I ever?).
Is this because BRW is stiff enough to go so thin?
PostPosted: Tue Oct 04, 2005 3:30 pm
Where is that envy icon when I need it! Nice find Brock.
PostPosted: Tue Oct 04, 2005 11:55 pm
It was just dumb luck.
PostPosted: Wed Oct 05, 2005 8:48 am
[QUOTE=Brock Poling] It was just dumb luck.[/QUOTE]
Be glad I don't live close. My ancestors weren't known to be horse "traders". I was told they decorated many a tree.
PostPosted: Wed Oct 05, 2005 3:22 pm
Stiffness is a big part of being able to go thin...as wood gets thinner it becomes less rigid or "floppy" which dramatically reduces the resonance of the piece of wood. It is a delicate balance between going thin enough to maximize resonance without taking it to the point were structural integrity is compromised.
There are a number of classical builders that are going very very thin with their tops and then to keep the top from collapsing reinforce the top with lattice bracing. While these guitars are much louder than traditionally built classicals, there are those that feel that with the tops very thin that it loses the tonal range (color) and loss of the overtones that fill out the sound.
Stiffness is not limited to Brazilian Rosewood as there are many woods that are stiff enough to be thinner than another species that is less stiff. Stiffness is obviously not limited to hardwoods either in that Sitka or Adirondack can be stiffer than a number of woods used for sides and backs.
